Unable to wake from hibernation on ls1028 platform
2,993 次查看
Eddy1
Contributor V
Hi:
Recently, we found that we can't wake up from sleep on the ls1028 platform(BSP  OPENIL1.10),
Here are my steps:
echo enabled > /sys/devices/platform/soc/21c0500.serial/tty/ttyS0/power/wakeup
echo mem > /sys/power/state
[ 43.989864] 001: PM: suspend entry (deep)
[ 43.998612] 001: Filesystems sync: 0.008 seconds
[ 64.621811] 001: cfg80211: failed to load regulatory.db
[ 64.623277] 000: Freezing user space processes ...
[ 64.624555] 001: (elapsed 0.001 seconds) done.
[ 64.624559] 001: OOM killer disabled.
[ 64.624562] 001: Freezing remaining freezable tasks ... (elapsed 0.055 seconds) done.
[ 64.680088] 001: printk: Suspending console(s) (use no_console_suspend to debug)
Then I type any character on the keyboard, but i find no response.Could you give me some suggestions to find out this problem?Thanks!
2,967 次查看
yipingwang
Please use the following command
echo 0 > /sys/class/rtc/rtc1/wakealarm && echo +5 >/sys/class/rtc/rtc1/wakealarm && echo mem > /sys/power/state
11 回复数
2,986 次查看
yipingwang
Required fsl,rcpm-wakeup property should be added to a device node if the device
can be used as a wakeup source.
- fsl,rcpm-wakeup: Consists of a phandle to the rcpm node and the IPPDEXPCR
register cells. The number of IPPDEXPCR register cells is defined in
"#fsl,rcpm-wakeup-cells" in the rcpm node. The first register cell is
the bit mask that should be set in IPPDEXPCR0, and the second register
cell is for IPPDEXPCR1, and so on.
Note: IPPDEXPCR(IP Powerdown Exception Control Register) provides a
mechanism for keeping certain blocks awake during STANDBY and MEM, in
order to use them as wake-up sources.
Example:
lpuart0: serial@2950000 {
compatible = "fsl,ls1021a-lpuart";
reg = <0x0 0x2950000 0x0 0x1000>;
interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&sysclk>;
clock-names = "ipg";
fsl,rcpm-wakeup = <&rcpm 0x0 0x40000000>;
2,976 次查看
Eddy1
Contributor V
Hi:
In addition, on the layerscape ls1028a reference design board, the results are the same.
Build image by:
$ cd openil
$ make nxp_ls1028ardb-64b_defconfig
$ make
The wake-up log:
[root@LS1028ARDB ~] # echo +5 > /sys/class/rtc/rtc1/wakealarm
[root@LS1028ARDB ~] # echo mem > /sys/power/state
[ 77.734072] 001: PM: suspend entry (deep)
[ 77.736608] 001: Filesystems sync: 0.002 seconds
[ 77.737647] 000: Freezing user space processes ... (elapsed 0.001 seconds) done.
[ 77.738885] 000: OOM killer disabled.
[ 77.738888] 000: Freezing remaining freezable tasks ... (elapsed 0.079 seconds) done.
[ 77.818525] 000: printk: Suspending console(s) (use no_console_suspend to debug)
[ 78.461229] 001: rtc-pcf2127-i2c 4-0051: oscillator stop detected, date/time is not reliable
2,968 次查看
yipingwang
1,993 次查看
PaulGreenwood
I've tried the suggested command:
but it hangs until the watchdog timer reboots the system.
I'm on an LS1028ARDB board and running:  NXP LSDK 2108 main (custom based on ubuntu 20.04)
Ideas?
1,624 次查看
PaulGreenwood
After changing OS images, this works but I'm limited to 262 seconds of sleep time.  Any ideas on how to make this longer?
2,962 次查看
Eddy1
Contributor V
Hi:
Thank you very much for your help.Entering in mem mode by putting your command. And after that MPU  wakes.
2,984 次查看
Eddy1
Contributor V
Hi:
Thank you for your reply, but it still doesn't work!
2,968 次查看
yipingwang
I just confirmed with LSDK development team, waking up from UART is not supported.
2,884 次查看
Eddy1
Contributor V
Hi:
Thank you for your reply. Does it support wake-up from GPIO?I added the wake-up attribute, but it didn't work.
gpio_keys: wakeup_keys@0 {
compatible = "gpio-keys";
user {
label = "User";
gpios = <&gpio3 3 GPIO_ACTIVE_HIGH>;
gpio-key,wakeup;
linux,code = <KEY_1>;
fsl,rcpm-wakeup = <&rcpm 0x0 0x0 0x0 0x0 0x200 0x0 0x0>;
2,864 次查看
yipingwang
Please refer to the procedure in page 1308 in LSDK 20.12 user manual.
2,857 次查看
Eddy1
Contributor V
Hi:
Thank you very much for your help.Now it works.
