I've read the data sheet of lx2160a & ls2088, but I'm still comfused.
I want to know if these two CPUs support shared memory?
Thanks.
Kentin_Cheang
What do you mean by the "Shared Memory"?
Hi ufedor,
One process must explicitly ask for an area, using a key, to be shared by other processes. This process will be called the server. All other processes, the clients, that know the shared area can access it.
I would like to use this way to implement an application, but I search the key word ,shared memory, through the data sheets of lx2160a & ls2088, there is no result of it.
Kentin
Described functionality is a software one - it should not be mentioned in the processor's hardware specifications document.
Hi ufedor,
thanks for the reply,
could you tell me where can I find the documents?
Kentin_Cheng
It is reasonable to post request in a forum/community, devoted to the operation system which you are planning to use.
