Hi all,
It is known that SerDes Core supply SVDD can be taken either from a separate 0.9V/1.0V source or from Core VDD. So, Please let me know which is better and how?
Thanks in Advance
SVDD needs to be sourced from a separate regulator in LS1088A, so a separate regulator is required for common board to source SVDD - refer to the AN5226 - Common Board Design for LS1046A, LS1043A and LS1088A Processors.
OK! what about LS1046A? Will it be ok to give SVDD from a separate regulator?
Yes.
