Not able to change Port speed using ethtool on LS-1088ARDB-PB
ashutoshharry
Hi @yipingwang
i am not able to change port speed as its 10G interface and want to change it to 1G for traffic testing.
any clues will be helpful
logs and command below:
root@OpenWrt:~# ethtool eth1
Settings for eth1:
Supported ports: [ ]
Supported link modes: Not reported
Supported pause frame use: No
Supports auto-negotiation: No
Supported FEC modes: Not reported
Advertised link modes: Not reported
Advertised pause frame use: No
Advertised auto-negotiation: No
Advertised FEC modes: Not reported
Speed: 10000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
MDI-X: Unknown
Link detected: yes
root@OpenWrt:~# ethtool -s eth1 speed 1000 duplex full
Settings for eth1:
Speed: 10000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
MDI-X: Unknown
Link detected: yes
Cannot advertise speed 1000
root@OpenWrt:~# dmesg -n 8
Settings for eth1:
Speed: 10000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
MDI-X: Unknown
Link detected: yes
root@OpenWrt:~#
yipingwang
This operation is not supported in LSDK or OpenWrt.
ashutoshharry
Settings for eth1:
Speed: 10000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
MDI-X: Unknown
Link detected: yes
root@OpenWrt:~# ethtool -s eth1 speed 1000 duplex full autoneg off
root@OpenWrt:~#
Settings for eth1:
Speed: 10000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
MDI-X: Unknown
Link detected: yes
yipingwang
ashutoshharry
Settings for eth1:
Speed: 10000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
MDI-X: Unknown
Link detected: yes
root@OpenWrt:~#
Settings for eth1:
Speed: 10000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
MDI-X: Unknown
Link detected: yes
same result
yipingwang
Do you use dpmac.1 or dpmac.2?
dpmac.1 is optical port, it cannot be switched to 1G mode.
dpmac.2 is copper port, you could try the following command.
