LX2160A-RDB: CPU stuck in reset after incorrect entry point set
userland
A pbl with an entry point was flashed to flexspi flash to a LX2160A-RDB rev2, and the board is stuck in reset with D22 and D19 LED on.
Attempts have been tried to change where to load the RCW with SW1[1:4] and that results in none of the error LEDs on but still no access to the CPU through JTAG
What's the best way to recover from this?
userland
For some reason lx2160-spi-rcwovr.cmm didn't work for me, and the CPU was still in reset.
But a solution I found to work was running lx2160a-ca72_sieve_ocram_failsave.cmm and then flashing a working PBL+RCW and the RDB is working again.
userland
