LS1012A Yocto Ubuntu root fs modules not loading by name
1,023件の閲覧回数
epoletaev
I'm compiling Yocto on kirkstone branch
repo init -u https://github.com/nxp-qoriq/yocto-sdk -b kirkstone -m ls-5.15.71-2.2.0_distro.xml
All seems working well except of kernel modules which I can load only by providing full file path to insmod command.
Is there a way to fix it?
4 返答(返信)
1,002件の閲覧回数
khushbur
Hi @epoletaev
Can you please elaborate more which kernel module you want to load?
Please change your kernel configuration file accordingly.
Khsuhbu
995件の閲覧回数
epoletaev
Every module that listed in /boot/modules are not loading by name and only loading by full path
insmod any
Not found
insmod /boot/modules/full/path/any.ko
Loaded
Lets say for example usbserial.ko
969件の閲覧回数
khushbur
Hi @epoletaev
Can you please try with modprobe
Please run below command
sudo ln -s /path/to/module_name.ko /lib/modules/`uname -r`
sudo depmod -a
sudo modprobe module_name
Khushbu
959件の閲覧回数
epoletaev
That would work, but it is just workaround is there real fix for the issue?
