LS1012A Cannot login automatically as root
lyh20218
Hi!
     I want to login automatically as root after the system boot and no password required! I've tried modify “/lib/systemd/system/getty@.service” content as follows:
annotate "#ExecStart=-/sbin/agetty -o '-p -- \\u' --noclear %I $TERM"
and add "ExecStart=-/sbin/agetty --autologin root --noclear %I $TERM" or "ExecStart=-/sbin/agetty -a root --noclear %I $TERM",but it didn't work!
    Second:modify "/etc/passwd",change "root:x:0:0:root:/root:/bin/bash" to "root::0:0:root:/root:/bin/bash".
    Now I don't need to enter a password,but still need to enter a user name "root".
    Why doesn't it work?
Startup information:
[ OK ] Started Permit User Sessions.
[ OK ] Started vsftpd FTP server.
[ OK ] Started Serial Getty on ttyS0.
Starting Set console scheme...
[ OK ] Started Ubuntu FAN network setup.
[ OK ] Started Set console scheme.
[ OK ] Created slice system-getty.slice.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Started LSB: HPA's tftp server.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started LSB: network benchmark.
[ OK ] Started Lighttpd Daemon.
[ OK ] Started LXC network bridge setup.
Starting LXC Container Initialization and Autoboot Code...
[ OK ] Started LXC Container Initialization and Autoboot Code.
[ OK ] Started Samba NMB Daemon.
Starting Samba SMB Daemon...
[ OK ] Started Virtualization daemon.
Ubuntu 18.04.1 LTS localhost ttyS0
localhost login: root
Last login: Sun Jan 28 15:58:27 UTC 2018 on tty1
Welcome to Ubuntu 18.04.1 LTS (GNU/Linux 4.14.47 aarch64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
root@localhost:~#
yipingwang
Hello li yh,
Please edit /etc/init/tty1.conf and replace the exec /sbin/getty ... line with:
exec /sbin/getty -n -l /bin/sh -8 38400 tty1
Yiping
lyh20218
Hi!
Thank you for your reply!
But the file "tty1.conf" does not exist in the path "/etc/init/",
Is there any other way to solve this problem?
yipingwang
Please edit the file /lib/systemd/system/getty@.service and change the line
ExecStart=-/sbin/agetty --noclear %I $TERM
to
ExecStart=-/sbin/getty/ --noclear -a root %I $TERM
lyh20218
Hi!
Now I've found a way to solve this problem:
edit the file /lib/systemd/system/serial-getty@.service and change the line
ExecStart=-/sbin/agetty -o '-p -- \\u' --keep-baud 115200,38400,9600 %I $TERM
to
ExecStart=-/sbin/agetty -a root --keep-baud 115200,38400,9600 %I $TERM
Thanks for your help!
