DRAM bus speed optimization test ls1021a
winstonjacob
I am using LS1021atwr board, here I need to do the DRAM bus speed optimization, please support me to do this test in LS1021atwr EVK board.
Winston
Bulat
Please clarify what means "DRAM bus speed optimization"?
Why do you think the DRAM bus speed is not optimized?
Bulat
winstonjacob
Thanks for your reply @Bulat
      I need to test the DRAM in various frequencies and various speed, is their any procedure available for this.
Winston
Bulat
Default DDR speed of the LS1021ATWR is 1600MT/s, this is a maximum possible speed for the LS1021A DDR controller. U-boot software provides setup for this speed.
If maximum possible speed is not "optimal" for you, you can test other speeds using DDR Validation tool, that is a part of QCVS. Note that DDR speed is defined by RCW, so for each DDR bus speed you will need to change RCW with desired MEM_PLL_RAT ratio. The tool will help with timing parameters for chosen bus frequency.
Bulat
