Can LS1012A support 1*5Gbps Ethernet by 2port trunk or PCIe?
AlanYL
Hi NXP,
About the LS1012A platform, can it support 5Gbps Ethernet with following question?
  1. Does LS1012A support Ethernet Trunk to combine 2*2.5Gbps into 1*5Gbps function via BSP setting?
  2. Does LS1012A support PCIe extension or any other suggestion to meet Ethernet 1port up to 5Gbps solution?
Thanks!
yipingwang
Please refer to "Table 28-2. Supported SerDes options" in LS1012ARM, it is impossible to configure a serdes lane as 5G.
