No connection to emulator device?
raphaelprechtel
I am using the NHS 3152 on the Eval-board "NHS3152THADADK", which has 13 switches. I changed the blinky demo software to get an output at GPIO 5 and 7. The other Pins I wanted to use as Inputs, to see whether I can detect my output signal on an Input pin, because of the internal connection caused by the switches.
After flashing my program I am not able anymore to connect to the microcontroller. I attached the code and the error message.
Somehow I think it was a bad idea to change the programming pins 10 and 11 to Input and that's why I can't connect to the core anymore.
I hope someone can help me.
Greetings,
Raphael
