Need to get going with profiling.
lpcware
Content originally posted in LPCWare by mhjerde on Thu May 19 03:13:18 MST 2011
I'm trying to get started with profiling.
Thinking a good first step would be to have the debugger generate profiling information. So I add the -pg flag, but this just results in a lot of error messages "undefined reference to `__gnu_mcount_nc'".
I've searched around but can't find out how to get started. For me, the ideal thing would probably be some sort of "profiling for dummies" resource. Any pointers?
blmckinley
I have selected profiling with gprof and am also receiving
errors at link time.
Any suggestions are appreciated.
blmckinley
Thank you - I had already found that. I had assumed they would come in some kind of SDK from NXP's universe.... I can't believe the MCUXpresso IDE environment supports profiling, but the user is forced to generate their own source for it.
If I use the linked article, how to get the gprof source programs, should I just copy and paste them into my project?
What about this alternative that at least lives on github? https://github.com/OP-TEE/optee_os/tree/master/lib/libutee/arch/arm/gprof
In my mind at least that code is open source and source-controlled.
I appreciate your help.
Bruce
