LPC55S16 - Flash IAP
1,083件の閲覧回数
Dhaya
We used the IAP Flash concept to store the data in our customised board. In some boards it works properly. But in some of the board, it not executed while entering the function of flash property controller get hanged. How can i resolve this issue. Here by I updated the code we generated
#include "fsl_iap.h"
#include "fsl_iap_ffr.h"
#include "init.h"
#define PAGE_INDEX_FROM_END 1U
flash_config_t flashInstance;
static uint32_t status;
uint32_t destAdrss; /* Address of the target location */
uint32_t failedAddress, failedData;
uint32_t pflashBlockBase            = 0;
uint32_t pflashTotalSize            = 0;
uint32_t pflashSectorSize           = 0;
uint32_t PflashPageSize             = 0;
void IAP_Flashwrite(void);
void IAP_Flashread(void);
void IAP_Address_cap(void);
int main()
IAP_Address_cap();
IAP_Flashread();
while(1)
void IAP_Address_cap()
FLASH_Init(&flashInstance);
/* Get flash properties kFLASH_ApiEraseKey */
FLASH_GetProperty(&flashInstance, kFLASH_PropertyPflashBlockBaseAddr, &pflashBlockBase);
FLASH_GetProperty(&flashInstance, kFLASH_PropertyPflashSectorSize, &pflashSectorSize);
FLASH_GetProperty(&flashInstance, kFLASH_PropertyPflashTotalSize, &pflashTotalSize);
FLASH_GetProperty(&flashInstance, kFLASH_PropertyPflashPageSize, &PflashPageSize);
destAdrss = pflashBlockBase + (pflashTotalSize - (PAGE_INDEX_FROM_END * PflashPageSize));
static uint8_t status;
status = FLASH_Erase(&flashInstance, destAdrss, PflashPageSize, kFLASH_ApiEraseKey);
status = FLASH_VerifyErase(&flashInstance, destAdrss, PflashPageSize);
/* Start programming specified flash region */
status = FLASH_Program(&flashInstance, destAdrss, (uint8_t *)IAP_data_buffer, sizeof(IAP_data_buffer));
// /* Verify if the given flash region is successfully programmed with given data */
// status = FLASH_VerifyProgram(&flashInstance, destAdrss, sizeof(Write_byte),
// (const uint8_t *)Write_byte, &failedAddress, &failedData);
/* Verify programming by reading back from flash directly */
for (uint32_t i = 0; i < 64; i++)
IAP_data_buffer[i] = *(volatile uint32_t *)(destAdrss + i * 4); //IAP_data_buffer
6 返答(返信)
996件の閲覧回数
Dhaya
We use Keil IDE which having the following configuration of RAM and ROM
940件の閲覧回数
Hello @Dhaya
Is your board custom board or demo board?
Can you confirm whether it can debug simple hello world demo well?
There is no issue with this demo, I have tested on my demo board.
Alice
919件の閲覧回数
Dhaya
We using our custom board.
878件の閲覧回数
Hello @Dhaya
Alice
1,052件の閲覧回数
Hello @Dhaya
How about first use SDK demo "flashiap1" to test ?
Alice
1,022件の閲覧回数
Dhaya
Hi @Alice_Yang ,
    No its not working fine. It shows the following error while debug SDK example project without edit.
IAP_flashiap1 LinkServer Debug [C/C++ (NXP Semiconductors) MCU Application]
IAP_flashiap1.axf [LPC55S16 (cortex-m33)]
Thread #1 1 (Suspended : Signal : SIGSTOP:Stopped (signal))
HardFault_Handler() at semihost_hardfault.c:53 0x2618
<signal handler called>() at 0xfffffff9
_printf() at 0x21a0
main() at iap_flash.c:58 0x2ce
arm-none-eabi-gdb (12.1.90.20221210)
