LPC Link2 USB PORT RESET FAILED ERROR
1,318件の閲覧回数
Sriharsha_Desai
Setup: MIMXRT685_EVK_CM33 board
Requirment: To debug / access console from UART from LINK usb. I am using J-Link to flash the program.
Problem: When I connect the EVK to USB of host. I am Not able to debug using LPC LInk2 and the device is not enumerated as COM port. In the device manager getting error as "USB Device PORT Reset Failed"
Note: I have updated the LINK usb with latest J-Link firmware using LPCScrypt tool.
How to restore the LPC of the NXP EVK?
タグ(2)
489件の閲覧回数
chris1058
Hello, @Sriharsha_Desai nystateofhealth
Certainly! To restore the LPC-Link2 on your MIMXRT685_EVK_CM33 board, follow these steps:
Navigate to the root directory where LPCScrypt is installed (e.g., C:\nxp\LPCScrypt\scripts).
Run the program_CMSIS script. This should help resolve the “USB Device PORT Reset Failed” issue. If you continue to face problems, consider contacting NXP TechSupport for further assistance.
I hope this will help you
1,301件の閲覧回数
Pavel_Hernandez
As same that you changed the firmware for the J-Link, using the LPCScript in root C:\nxp\LPCScrypt\scripts and run program_CMSIS.
Pavel
