printf causing hard fault in NewLibNano(semihost)
1,559 次查看
leo838
Hello All,
I recently tried running demo programs (provided in an LPC812 SDK) in debug mode on a LPC812 Xpresso board (eg. lpcxpresso812max_sctimer_16bit_counter ) & because of memory space constraints was forced to compile it with the Newlibano(semihost) library. This resulted during running in a hard fault (redirection to  function void HardFault_Handler(void)). Once the printf's were committed out the program executed normally.
Am I doing something wrong? From what I've read printf's should be supported in this library./ environment.
Leo
1,387 次查看
ZhangJennie
Hi leo838
I don't have exact LPC812 board in my hand, so I tested it with LPCXpresso824 demo board.
If you want to print to uart, I suggest you use Newlibano nohost. although I tested semihost lib also working, but using Newlibano nohost is my recommendation.
Please see my attached video, there is no hardfault while running the program. I suggest you follow the steps and test yours.
Jun Zhang
1,387 次查看
leo838
Jun,
Thanks for the reply.
I was under the impression that a semihost library was required to enable printf messages to be sent to the debug console. I tried your solution but unfortunately the same result. I then tried using the following:
quick setting> SDK debug console> semihost console
& together with the nohost library it solved the issue.
It seems, at least in my environment, that these settings are not retained during builds.
Thanks for your help
