nop函数实现延时
nop函数实现延时
710件の閲覧回数
wangyibin
利用nop在LPC55S69实现1s延时不精准?与窗口看门狗实现的1s相比,所用时间长了?
699件の閲覧回数
ZhangJennie
Hi wangyibin
It's not possible  to use code like nop implement precise delay time.
If precise delay is needed, please use timer. Please note, if using FRO as timer source, The FRO is +/- 2% accuracy over the entire voltage and temperature range.
Hope this helps,
Jun Zhang
