from LPC1788 to LPC4088 but the code flash size is the same
882 次查看
aut
Hi all.
I replaced the LPC1788 microcontroller with his pin-to-pin compatible LPC4088. Since there are a lot of single precision floating point calculations in the LPC1788 code, I thought this migration could reduce the size code using the FPU (floating point unit) of the LPC4088. I was wrong. Even if the FPU unit is enabled, the code size after compilation hasn't changed. It is the same as the LPC1788 one.
Shouldn't using the FPU reduce the code size?
Many thanks
4 回复数
834 次查看
frank_m
Senior Contributor III
Code size is not only about FPU usage.
What are the optimisation settings for the LPC4088 project ?
The floating point ABI matters as well (-mfloat-abi).
Using "soft" will result in an emulation, as on the LPC1788 (without FPU).
Using "softfp" will use the FPU, and the core registers for passing parameters.
The option "hard" will produce marginally smaller/faster code, passing parameters in FPU registers.
Code compiled with soft/softfp is interchangeable, code compiled with "hard" is not.
852 次查看
aut
Hello Alice. Can I have confirm that FPU increase only the floating point calculation speed but don't reduce the code size?
Thank you
838 次查看
Hello aut,
I think there is no direct relation between them.
Alice
862 次查看
Hello aut,
As I know, the  FPU (floating point unit) can speed up floating point calculation, don't know whether can reduce code size.
Alice
