Hello
After updating to Windows 11 is blhost is unable to open USB HID Device.
Tested on LPC55S69-EVK.
Example blhost command:
LPC55S69 Boot-HID device is found/enumerated correct by PC:
Exact same command works fine on PC running Windows 10:
(Same PC hardware / USB connection - Windows 10 PC running as virtual machine).
Question: Why does blhost not connected to LPC55S69 bootloader when running on Windows 11 PC?
Regards Knud
@Pavel_Hernandez
We are also seeing this issue. It seems to work on Windows 11 version 21H2 but it is NOT working on a later version on a different computer.
Is there any resolution or workaround to this problem?
We are also facing the same issue. I have also raised it few weeks back. When I testes it around March of this year it was working fine. I also had windows 11 at that time. But now it is not working. Now the Windows 11 version is 23H2. Can you please provide us some solution.
Thanks for your help in advance.
Im seeing the exact same thing. blhost usb hid works on Win 10 not Win 11.
Has this issue been resolved?
Unfortunately not solved
Pavel Hernandez (NXP Support) does no recommend to use blhost
Pavel says that SPSDK work fine on his Win 11 setup, but it does not work on my Win 11 PC.
SPSDK also require installation of Phyton interpreter, which is to complicate for use in our product Service center.
I am still very interested in using blhost on Win 11 - maybe you are able to find solutiuon
How did your test on Windows 11 go?
Hello, I did the test, and this is my result.
Pavel
Hello, my apologize I will test it at these days.
Pavel
Hello, my name is Pavel, and I will be supporting your case, I suggest using the SPSDK this is the newest tool that has integrated a bunch of tools into one site.
Installation Guide — SPSDK documentation
Pavel
Hi @Pavel_Hernandez ,
I am facing the similar issue. I am using the MCUBootUtility to program the board using OTA bootloader. The bootloader was working fine previously. But now when I try to connect using the BootUtility tool it is giving the following error ' Failed to ping SBL ISP component, Please double check it is SBL target!'.
I can see the USB is enumerated as HID but not able to connect to SBL. Your quick help on this is highly appreciated.
Thanks.
Hello Pavel
Thanks a lot for fast response
Have installed SPSDK, but have more or less same problem – see screen dump below:
But, I am looking for a ‘simpler’ tool than installing Python interpreter + SPSDK package – here blhost.exe is perfect.
Need the tool for 2 purposes:
Questions:
PS.: Same problem on LPC55S69-EVK and LPC55S66 used in our application
Regards Knud
Hello, I tested it on my side and then had the same issue, but then I saw you miss a 0 on the PID section, try with 0x0020.
Let me know if the issue is still there.
Pavel
Hello Pavel
Again, thanks for your reply – very appreciated.
Have made 2 new test with correct PID parameter: No change / same problem
Knud
Hello, did you put the Board in ISP mode?
I test it on my side with the LPC55s69 with the HS-USB (P9) and the ISP button (S1).
Pavel
Hello, I confirm with your image you have the ISP mode, are you using LINUX?
Pavel
Hello Pavel
Yes, I press and hold S1-ISP button while plugging USB cable into P9
(boot loader only activate if S1-ISP pressed during reset)
As already written, this problem only occurs when running on Windows 11 Pro system.
If I run a virtual Windows 10 Pro on same hardware (and same PC USB port) does blhost.exe run correct.
Please try to replicate problem on PC running Windows 11 Pro…
Knud
Hello, I apologize I do not have at moment the board at home, my personal computer has win11, I have an OKDO, and I tested it but with VCOM.
The Win11 is communicating and is discarded, could you review if the jumpers are in default position? Could you please download the document and review the Table 1. Indicators, buttons, connectors and LEDs?
LPCXpresso55S69 Development Board | NXP Semiconductors
Pavel
Hello Pavel
Thanks for your work on this issue, but this is a completely different test you made.
Let me summarize my findings:
From this I conclude: Problem is related to USB connection on Windows 11
The goal is to have a simple Windows problem that are able to firmware update via built in bootloader, which is fulfilled by blhost.exe
We do not like SPSDK because it also requires installation of Python interpreter, but it’s of cause OK for tracing the real problem with blhost.exe
Please make correct attempt to replicate problem: Windows 11 + USB connection.
Best regards Knud
Hello, sorry but I could not offer a good solution if you are using the VMW this is beyond the scope, could you test it on native WIN11?
Pavel
Hello Pavel
The problem is on native Windows 11.
I only use VMware to run older Windows 10 for further testing - and here it works fine
Running this test shows that cabling, USB hardware on PC, Switches / Jumpers on LPC55S69-EVK, command line parameters for blhost.exe, etc. is correct.
Knud
