Write cycles for programming flash page in multiple steps
688 次查看
remco2
I want to program a flash page of the LPC824 in 16 blocks of 4 bytes. The blocks are consecutive, so I only program erased bytes. How does this count towards the flash endurance cycles? Is it only the single erase that counts? Or does each and every program action also count as a cycle?
Thanks in advance.
Kind regards,
Remco Poelstra
标记 (2)
477 次查看
jeremyzhou
Hi Remco Poelstra,
1) How does this count towards the flash endurance cycles?
To program these consecutive blocks, I'd like to suggest you to use the IAP command-Copy RAM to flash command to achieve it and it counts one cycle.
Hope it helps.
Ping
478 次查看
jeremyzhou
Hi Remco Poelstra,
Hope it helps.
Ping
