Wire ACK Fault in DAP Access
次の代わりに検索
409件の閲覧回数
caden013
15: Target error from Register access
Wire ACK Fault in DAP access
Debugging context: Analog Testing_spi_interrupt LinkServer Debug
Hi all, I am getting the error shown above ^^^. The culprit is the "CTIMER4" in the following function: CTIMER_Init(CTIMER4, CTIMER_config). When I replace "CTIMER4" with 0, I don't receive this error. Can anyone help me out?
タグ(1)
2 返答(返信)
397件の閲覧回数
Hello caden013,
Yes, As Frank said, please first check have you enable CTIMER4 clock.
If still has issue, please share your whole project.
Alice
402件の閲覧回数
frank_meyer
Senior Contributor III
Perhaps you need to enable the clock to the peripheral first ?
The peripheral unit needs to be enabled first (including the clock), before you can access the register. Other MCUs throw hardfaults if you try to access registers in non-clocked peripherals.
For my MCU (LPC546xx), the respective SDK call is CLOCK_AttachClk() in fsl_clock.c.
