What voltage regulators should I use for the LPC11C24?
519 次查看
matthewfilibert
The LPC11C24 needs 3.3V and 5V (for CAN). Could anyone recommend me some stable voltage regulators to use? My input will be 12V.
One concern I have is current draw. I noticed that voltage regulators have a minimum current load requirement in order to be stable. After some research, I estimate that I should be drawing from 5-50mA for the 5V regulator (powers CAN transceiver) and around 10mA for the 3.3V  regulator (powers microcontroller and a current sensor).
标记 (2)
401 次查看
juanabelaira
Usually that minimum current is fairly small, a few mA, you could have just an LED to tell the thing is powered up.
I would first guess what your maximum current is, I assume not more than 100 mA, so you can choose a linear regulator with those ratings:
Vin > 12V, Vout 3V3 or 5V, Iout >= 100mA
An additional note on power: for 12V in, 3V out you will dissipate 0,9W at 100 mA. That's relatively a lot, the smallest packages (SOT-23) may not cope with that, check the ones in DPAK, etc. Also, for your PCB, keep a decent copper area and vias to ground plane for heat sinking.
Alternatively, the cooler although pricier way is to have a switching regulator. You can get 90% efficiency but will have to design it, put more components, etc.
401 次查看
soledad
You can use some schematic file as reference, for example check the below link:
https://www.olimex.com/Products/ARM/NXP/LPC-P11C24/resources/LPC-P11C24_revision_A_sch.pdf
Sol
