Sudden Power Outage LPC1857
555件の閲覧回数
rubensjunior
Hi friends,
I would like to know how it is possible to save the value set for a variable in flash memory moments before a sudden shutdown of the LPC1857 microcontroller's power supply.
Thanks a lot!
Rubens Júnior
525件の閲覧回数
xiangjun_rong
I suppose that you can connect a large bypass capacitor on the 3.3V power supply pins, the LPC1857 has BOD, which can detect the power supply voltage, when the voltage is less than a threshold which is programmable, the BOD will fire an interrupt, in the BOD ISR, you can write the important data to on-chip EEPROM or flash. Because large capacitor is connected, it can keep a long time so that the data can be written reliably.
XiangJun Rong
3 返答(返信)
526件の閲覧回数
xiangjun_rong
XiangJun Rong
420件の閲覧回数
rubensjunior
Dear @xiangjun_rong,
Please can you help me to find code examples with BOD implementation for LPC1857?
Rubens Júnior
405件の閲覧回数
xiangjun_rong
Unfortunately, I do not get the BOD example for the LPC1857, but there is BOD example in the LPCOpen package for the LPC4088, pls refer to it.
Hope it can help you
XiangJun Rong
