Sending a byte using UART
Search instead for
emimad
Hi all!
I'm trying to send some bytes through UART but I'm having some problems, probably because my old programming memories.
uint8_t array[]={0x80, 0x30, 0x31, 0x50};
for(i=0;i<4;i++){
Chip_UART_SendByte(LPC_USART, array[i]);
I'm sure it's an stupid question... but after check many examples I can't send my array byte by byte
Thanks in advance!
emimad
Thank you Diego!
I'm using a LPCXpresso LPC1347 board with MCUXpresso  IDE v11.4.0 and LPCOpen v2.05.
I tried your function:
Spoiler
Chip_UART_Send(LPC_USART, "UART_Send!\n\r", 12);
Chip_UART_Send(LPC_USART, (const uint8_t *) &array[i], 10);
Chip_UART_Send(LPC_USART, (const uint8_t *) array[i], 10);
Chip_UART_SendBlocking(LPC_USART, "\n\rUART_SendBlocking\n\r", 21);
Chip_UART_SendBlocking(LPC_USART, (const uint8_t *) &array[i], 10);
Chip_UART_SendBlocking(LPC_USART, (const uint8_t *) array[i], 10);
/* Transmit a byte array through the UART peripheral (non-blocking) */
int Chip_UART_Send(LPC_USART_T *pUART, const void *data, int numBytes)
int sent = 0;
uint8_t *p8 = (uint8_t *) data;
/* Send until the transmit FIFO is full or out of bytes */
while ((sent < numBytes) && ((Chip_UART_ReadLineStatus(pUART) & UART_LSR_THRE) != 0))
Chip_UART_SendByte(pUART, *p8);
p8++;
sent++;
return sent;
/* Transmit a byte array through the UART peripheral (blocking) */
int Chip_UART_SendBlocking(LPC_USART_T *pUART, const void *data, int numBytes)
int pass, sent = 0;
while (numBytes > 0) {
pass = Chip_UART_Send(pUART, p8, numBytes);
numBytes -= pass;
sent += pass;
p8 += pass;
return sent;
And this is the output:
Chip_UART_Send only sends the first character but not the first byte of my array
diego_charles
Hi @emimad
I hope you are doing well!
Could you let me know  which LPC board/MCU  and LPC drivers are you using?
Are you able to see any  part of your transmitted data array in the TX pin?  Or fails completely?
As a quick comment,  I would better call that function as below :
  int sent = 0;
     p8++;
     sent++;
  return sent;
This is done in the LPC4347 LPCopen drivers.
And  make sure that the RX pins and the UART are properly clocked and configured as the UM mentions.
All the best ,
Diego.
emimad
Thank you Diego!
Spoiler
int sent = 0;
p8++;
sent++;
return sent;
int pass, sent = 0;
numBytes -= pass;
sent += pass;
p8 += pass;
return sent;
