Reg: LPC845 ADC maximum Negative Voltage to withstand.
419件の閲覧回数
PK_1114
Hai,
What is the maximum allowable negative voltage on the ADC Pin in LPC845 Micro controller operating on the +3.3V.
Thank You,
B Pavan Kumar
タグ(1)
2 返答(返信)
359件の閲覧回数
ZhangJennie
Hi PK_1114
According to datasheet, ADC anolog input limit is as below
It is recommended to connect an overvoltage protection diode between the analog input pin and the voltage supply pin.
Have a nice day,
Jun Zhang
390件の閲覧回数
PK_1114
Is there any Reverse Protection in the LPC845 ADC pin, if there what is it voltage tolerance. I need to give the Sinusoidal wave to the ADC.
Thank You,
B Pavan Kumar
