Hello Guys,
I am using LPC824 board and want to read tacho signals from one of the pins.I have problems with enabling the right interrupts and clearing the flags. Could you help me
#include "fsl_debug_console.h"
#include "pin_mux.h"
#include "board.h"
#include "fsl_gpio.h"
#include <stdbool.h>
#include <stdio.h>
* Definitions
#define BOARD_LED_PORT 0U
#define BOARD_LED_PIN 12U
#define TACHO_PIN 17U
volatile uint32_t captureCounter = 0;
volatile bool captureEnabled = true;
* Code
void GPIO_IRQHandler(void)
// Check if the interrupt is caused by TACHO_PIN rising edge
if (GPIO_PinRead(GPIO, 0, TACHO_PIN))
captureCounter++;
// Clear the interrupt flag
//GPIO_PortClearInterruptFlags(GPIO, 0, 1U << TACHO_PIN);
void delay(uint32_t ms)
uint32_t ticks = ms * (SystemCoreClock / 1000U);
while (ticks--)
__asm("nop");
int main(void)
/* Init board hardware */
BOARD_InitBootPins();
BOARD_InitBootClocks();
BOARD_InitDebugConsole();
/* Configure TACHO_PIN as an input with interrupt on rising edge */
gpio_pin_config_t pinConfig = {
kGPIO_DigitalInput,
0,
GPIO_PinInit(GPIO, 0, TACHO_PIN, &pinConfig);
// Enable the GPIO interrupt
NVIC_EnableIRQ(PIN_INT0_IRQn);
while (1)
// Capture for approximately 1 second
delay(1000000U);
// Disable GPIO interrupt
NVIC_DisableIRQ(PIN_INT0_IRQn);
// Print the frequency over the last second
PRINTF("\r\nFrequency (last second): %u Hz\r\n", captureCounter);
// Reset the capture counter for the next measurement
captureCounter = 0;
// Enable GPIO interrupt for the next measurement
已解决! 转到解答。
Hi @vivekgourav
Under the LPC824max's SDK file you will find an example called lpcxpresso824max_pint_pin_interrupt, which shows how to use the PINT to make the pin interrupt events.
I hope this helps, let me know if you have a question.
Best Regards, Miguel.
Thanks for your quick response.
Also, On the LPC824, I wanted to use two timers, 1 timer for capturing PWM signal. and the other timer enables the pin interrupt at t second and disables at t+1 second. How to implement this
Hi @vivekgourav
I recommend you to look into example lpcxpresso824max_sctimer_16bit_counter, it might help you with the PWM match routine.
I'm not understanding your second inquiry, "other timer enables the pin interrupt at t second and disables at t+1 second."
Usually the interrupts are configured and only called when the event occurs, there is no need to disable or enable it, can you provide more details about this implementation?
Hi @vivekgourav
