Hi. I'm using a free-standing LPC832 - not part of any EVK - and the SWD connections as referenced in *1 work fine if I'm using the J-Link debugger. However, if I debug with LinkServer and the MCU-Link Pro, with the same pin connections, I get the following:
02: Failed on Connect
Target marked as not debuggable.
Probe(0): Connected&Reset
Remote communication error. Target disconnected.: Connection reset by peer.
Does the stand-alone LPC832 not support CMSIS-DAP debugging? Are my pins connected incorrectly? I could flash the MCU-Link Pro with Segger firmware and use it as another J-Link debug probe, but I'd rather have two types of probes.
Solved! Go to Solution.
I figured it out: the TDO pin needs to be connected for CMSIS-DAP debugging. Evidently, this is not necessary with J-Link debugging - as I've experienced in actual practice. The MCU-LINK Pro schematic helped. See page 4, "Cortex Debug (SWD/JTAG) interface."
https://www.nxp.com/downloads/en/schematics/MCU-LINK-SCH.pdf
Some debug probes have configurable options to enable/disable the 3.3V supply to the target through the debug adapter.
Perhaps this is your problem ?
Good point, but MCU-Link (base model) cant power a target. MCU-Link Pro can.
