Hi, I have a need to calculate FFT on sensor data, using an LPC825 target, testing on 825Max devbrd.
I believe the right approach is CMSIS DSP Math libraries. I am able to get the source to compile in my project, but the flash requirement is 333% of that in the LPC825. Now trying to use 'headers' with link to compiled .a library, to make sure i can it to fit in the 825.
I followed the instructions:
- import that libraries into MCUXpresso IDE
- Run new project wizard, select the Library Headers:
The project complies initially, but when I add the code from this example
- https://arm-software.github.io/CMSIS_5/DSP/html/group__FrequencyBin.html
I get this error, which is not surprising, as I've not linked the library yet.
In settings I have these libraries in the new project by default:
And no libraries or lib search paths. So adding:
- libCMSIS_DSPLIB_CM0.a
- C:\nxp\MCUXpressoIDE_11.7.1_9221\ide\Examples\CMSIS_DSPLIB\CMSIS_DSPLIB_Latest\CMSIS_DSPLIB_CM0
Doesn't successfully compile:
I'm pulling my hair out. Please help before I am bald!!
Hi Alice, this didn't have any effect. Error changed to:
Thanks, This seems to be a move in the right direction...
But the SDK I generate doesn't actually have the /lib/libCMSIS_DSPLIB_CM0.a directory or file in it. Or the examples, even though I have selected CMSIS DSP Library in the SDK generation.
I think it's for an older IDE version and changes have been made since. I will try again with fresh eyes today.
Is there someone in the FAE team who might be able to quickly put a "Hello World" together for me with the libCMSIS_DSPLIB_CM0 library linked? My target is the 824MAX development board, archive and send it thru. I might even send you beer. Otherwise I'll keep trying...
This was the default case with another vendor's MCU I made a few DSPLib applications for.
The ARM DSPLib comes with sources, and examples. Just use the source files instead and include them into your project, perhaps take a DSPLib example as template.
Yes, that would be standard behavior for GCC.
The "lib" prefix and ".a" suffix are automatically added to every name specified with "-l<lib>".
Not sure what Eclipse/LPCXpresso adds to the mix.
I would try to add the library via Drag&Drop, and add the library folder to the search path list.
