we are thinking about using LPC55xx family for a new project.
Do you know if the SDK provided by NXP for every uC model is compatible with Keil uVision too?
Thank you
Solved! Go to Solution.
Hi Matteo,
In the moment you download the SDK you can select for which IDE you need, MCUXpresso, IAR and Keil are the IDEs supported.
Alexis Andalon
Hi Matteo,
Alexis Andalon
Thank you very much Alexis,
I had missed it!
