My requirement is to use ethernet with normal http example using LPC54618J512 controller. Where I can get the sample code?.
Hello @Alice_Yang
Thanks for your reply. As per your instruction download the lwip_httpsrv_mbedTSL_bm sdk code and its working. This demo application board act as server and pc act as a client. But my requirement is pc should server and board as a client. So for this is there any sdk code is available?
Nithin
Hello @nithin3200
How about the demo "lwip_dhcp_bm"?
All the lwip demos are under lwip_examples folder, you can check the readme to lean each example.
Alice
Hello @Alice_Yang,
Thanks for the reply. "How about the demo "lwip_dhcp_bm"?". Actually, I required https protocol only.
I have gone through all the lwip demos are under lwip examples folder. In that lwip_httpssrv_mbedTLS_bm and lwip_httpssrv_mbedTLS_freertos, these two codes only for https remaining all are for other protocols.
As I mentioned in previous message these two codes Lpcxpresso 54628 board act as a https server and pc as a client. but my requirement is that board should act as client and pc as a server. For this application can I get any API?
Nithin
If demo code board act as a server. In the code where they initialize client and server configuration.
Nithin
Hello Alice,
This demo board server code if I want to send dynamic values to web page. What I need to do?
Nithin
Hello @Alice_Yang
Thanks for your reply. I tried lwip_httpssrv_mbedTLS_bm sample code. I don't have much Knowlege on HTTPS protocol. so where can get?
Hello @nithin3200
" so where can get?"
->> Sorry, do you ask where get the example code?
If yes, download SDK as I said above, then you can find it.
Alice
Hello @nithin3200
How about the examples under SDK:
Download SDK from:
https://mcuxpresso.nxp.com/en/select
It support MCUXpresso IDE, KEIL and IAR.
Alice
