LPC54018 XIP with IAR not working
686件の閲覧回数
danielgull
Hardware and Software setup:
I am currently working with the "OM40003 LPCXpresso54018 Development Board" and the MCUXpresso "SDK_2.7.0_LPCXpresso54018" with the IAR toolchain. I can compile the "demo_apps" "hello_world" using the IAR toolchain "8.22.1.15700" and flashing with "SEGGER JLink V6.62b, compiled Feb 17 2020 18:41:45"g. In addition to the development board I have mounted the "OM13099: Dual CAN-FD transceiver shield" which allows me to access the FLEXCOMM8 as debug output.
Problem XIP (Execute in place from SPIFI NOR flash) does not work:
The IAR linker file "LPC54018_spifi_flash.icf" provided with this demo app by default flashes the application into the SRAMX and runs fine out of the box without any issues. When I want to run the application from SPIFI. the application does not run out of the box. Attached are both versions of this example for your reference. What am I doing wrong? How can I get the application to run from SPIFI?
Many thanks
Dani
タグ(3)
591件の閲覧回数
jeremyzhou
Hi Daniel Gull,
To provide the fastest possible support, I'd recommend you to run hello_world_qspi_xip for testing, this demo is an external flash XIP demo, CPU will execute the code in external flash.
TIC
3 返答(返信)
591件の閲覧回数
danielgull
Hi Jeremy,
Thanks for the suggestion. I tried the application and could not flash, then I tried a spare Xpresso board and I can now flash the firmware. Seems like the board was defect.
Dani
591件の閲覧回数
danielgull
Attached also the Debug Log with IAR 8.40.2.22891
592件の閲覧回数
jeremyzhou
Hi Daniel Gull,
TIC
