LPC54018 USB In-System Programming
次の代わりに検索
807件の閲覧回数
mohd_
Anyone has experienced with usb isp mode using LP54018?
Is there any document/sample project that I can refer to other than the user manual?
Thank you.
763件の閲覧回数
mohd_
798件の閲覧回数
belmontbob59
You should read on chapter 3 (non secure) and 4 (secure) based on your specific need.
Based on ISP / OTP bits, NXP boot allows you to download and launch a firmware  from USB into RAM. If you want to program internal flash then you need to write a firmware to do or you can re-use mcu-boot (part of the SDK) to do so. i.e. :
1) ISP download MCU-boot from USB to RAM
2)use blhost.exe to interact with MCU-boot to actually program your custom firmware into flash.
