LPC1830 JLink can not download file
次の代わりに検索
1,625件の閲覧回数
andarm
- MCU: LPC 1830
- method : JTAG
- Error:  can connect successfully , then erase and download error.
- Hardware:  device running ok before. I just test it again, then I saw the problem.
1,596件の閲覧回数
OK, the Segger support also suggest to use latest J-link software:
Could you please retry with the latest version of J-Link software package?
https://www.segger.com/downloads/jlink/#J-LinkSoftwareAndDocumentationPack
5 返答(返信)
1,620件の閲覧回数
Hello andarm,
Recommend you first ask Jlink support:
https://www.segger.com/support/technical-support/
Also I can help you to contact if you need.
Alice
1,613件の閲覧回数
andarm
OK , Thanks very much.
I am not  convenient to communicate with segger's FAE.
Could you convert it .
1,601件の閲覧回数
Hello andarm,
OK, i have submit a ticket to Segger support team, will tell you after I get any reply, thanks.
Alice
1,599件の閲覧回数
andarm
Thank you very much . I found it can work in JFlashV4.92.  I think that   segger's software compatiable issue.
1,597件の閲覧回数
