LPC1830 JLink can not download file
Search instead for
andarm
- MCU: LPC 1830
- method : JTAG
- Error:  can connect successfully , then erase and download error.
- Hardware:  device running ok before. I just test it again, then I saw the problem.
OK, the Segger support also suggest to use latest J-link software:
Could you please retry with the latest version of J-Link software package?
https://www.segger.com/downloads/jlink/#J-LinkSoftwareAndDocumentationPack
Hello andarm,
Recommend you first ask Jlink support:
https://www.segger.com/support/technical-support/
Also I can help you to contact if you need.
Alice
andarm
OK , Thanks very much.
I am not  convenient to communicate with segger's FAE.
Could you convert it .
Hello andarm,
OK, i have submit a ticket to Segger support team, will tell you after I get any reply, thanks.
Alice
andarm
Thank you very much . I found it can work in JFlashV4.92.  I think that   segger's software compatiable issue.
