LPC1768 UART recieve problem
Search instead for
Alex_2221
Hello everyone, I'm trying to read two temperatures using LM35 and send them to a phone or computer using HC05 in order to control them. I want to send setpoints to the MCU. I tried to send different numbers ( 2 digit numbers) to the MCU and echo them, however I managed to recieve only the first digit of the numbers I was trying to send. I thought maybe I have problems in sending back the numbers  and I tried to use the recieved temperature in my code as a setpoint, but it didn't work.
 Here is my code. I also added the C file.
Thanks in advance, Alex
Code:
#include <stdio.h>
#include "lpc17xx_gpio.h"
#include "lpc17xx_pinsel.h"
#include "lpc17XX_uart.h"
#include "lpc17XX_adc.h"
#include "Hardware.h"
#include "Delay_RIT.h"
int main()
uint8_t buffstr [20];
uint8_t Temprec [1];
uint8_t temprec;
GPIO_SetDir(2,(1<<2),1);
HW_Init();
while(1)
uint16_t temp1 = HW_ADC_Read1();
uint16_t temp2 = HW_ADC_Read2();
uint8_t len= sprintf( (char*)buffstr," %u\n %u\n ",temp1,temp2);
UART_Send(LPC_UART3,buffstr,len,NONE_BLOCKING);
UART_Receive(LPC_UART3,Temprec,1,NONE_BLOCKING);
temprec= Temprec[0];
Delay_RIT_ms(1000);
if(temp1>=(temprec+1))
GPIO_ClearValue(2,(1<<2)) ;
else if ( temp1<=temprec)
GPIO_SetValue(2,(1<<2));
xiangjun_rong
How about using the code:
uint8_t counter;
while(1)
           counter=len-1;
while(1)
UART_Send(LPC_UART3,buffstr[counter],1,BLOCKING);
UART_Receive(LPC_UART3,Temprec,1,BLOCKING);
if(counter==0) break;
       counter--;
Delay_RIT_ms(1000);
pls have a try
XiangJun Rong
Alex_2221
I tested your code. I was able to receive the number that I send via HC05 successfully, but I don't recieve the temperatures of the sensors on my phone continously anymore.
Alex_2221
Thank you very much. I'll try it and will let you know if it works for me.
Alex_2221
I use this code for checking if the MCU can echo the number, but whenever I use UART_RECIEV (  blocking) I can correctly echo back the number, but it only works once and I can't recieve anything else from the MCU like the temperatures of the two sensors and if I use  UART_RECIEV (  none-blocking) I can only echo back the first digit of the number, but can recieve the temperature and change the number that I am sending as a setpoint:
UART_Receive(LPC_UART3,Temprec,2,NONE_BLOCKING);
UART_Send(LPC_UART3,Temprec,2,BLOCKING);
Alex_2221
@xiangjun_rong  What do you think about this?
