I'm using lwIP 2.1.2 on an LPC1766. I adapted the lwIP EMAC driver code from lpcopen_2_10_keil_iar_nxp_lpcxpresso_1769.
I've been having an issue where sometimes the Ethernet RX locks up — the processor's Ethernet MAC just stops receiving any packets, even though everything still appears to be configured normally in the MAC registers.
I tracked down the bug to the lwIP driver file lpc17xx_40xx_emac.c, function lpc_low_level_input(). The problem is the line:
p->len = (u16_t) length;
If the following if statement triggers (that is, if it is unable to allocate a new pbuf to replace the one just being taken for this received packet, due to low memory):
if (lpc_rx_queue(lpc_enetif->pnetif) == 0) {
then it re-queues the current pbuf:
lpc_rxqueue_pbuf(lpc_enetif, p);
However, because of the previous line that sets p->len to the length of this received packet, the pbuf now has a shorter length (the length of the packet just received), rather than its original length of ENET_ETH_MAX_FLEN. This means this pbuf is now unable to receive longer packets.
Once that bug happens a few times while receiving short packets, RX is effectively crippled in its ability to receive longer packets, and Ethernet RX effectively halts.
The fix is to move the line
to be just below the comment:
/* Save size */
ie where it also sets p->tot_len to the length.
Hello Craig,
Thanks a lot for your contributions.
Alexis Andalon
Will the LPCOpen downloads be updated with a fix?
Unfortunately, there is no news about further releases for LPCOpen so any comments and fixes about it are very appreciated.
Alexis Andalon
I'm surprised to hear this. It is very much in NXP's best interests to respond to user-submitted bug reports, and to fix known bugs promptly. By doing so, NXP will improve its reputation as a company that produces robust products.
It would be great if you could contact the people in NXP responsible for doing LPCOpen, and notify them of this bug report.
diff --git a/lpcopen_2_10_keil_iar_nxp_lpcxpresso_1769.old/software/lwip/lpclwip/arch/lpc17xx_40xx_emac.c b/lpcopen_2_10_keil_iar_nxp_lpcxpresso_1769/software/lwip/lpclwip/arch/lpc17xx_40xx_emac.c
index 09b39c2..892b389 100644
--- a/lpcopen_2_10_keil_iar_nxp_lpcxpresso_1769.old/software/lwip/lpclwip/arch/lpc17xx_40xx_emac.c
+++ b/lpcopen_2_10_keil_iar_nxp_lpcxpresso_1769/software/lwip/lpclwip/arch/lpc17xx_40xx_emac.c
@@ -275,7 +275,6 @@ STATIC struct pbuf *lpc_low_level_input(struct netif *netif) {
/* Zero-copy */
p = lpc_enetif->rxb[idx];
- p->len = (u16_t) length;
/* Free pbuf from desriptor */
lpc_enetif->rxb[idx] = NULL;
@@ -302,6 +301,7 @@ STATIC struct pbuf *lpc_low_level_input(struct netif *netif) {
p, length, idx));
/* Save size */
+ p->len = (u16_t) length;
p->tot_len = (u16_t) length;
LINK_STATS_INC(link.recv);
