Interrupt both edges on 13xx
06-15-2016
09:55 AM
1,053件の閲覧回数
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Content originally posted in LPCWare by mozmck on Tue Aug 27 17:23:47 MST 2013
I'm moving a project from an LPC1114 to a LPC1347 chip, and I'm not sure how to set up a pin interrupt to interrupt on both edges - rising and falling edges. Can I set it up so both rising and falling edge interrupts go to the same pin interrupt handler? In the LPC1114 this was easy and straight-forward, but in the 13xx chips it is not clear and the sample code does not show any way to do it at all.
It looks like I should be able to just set the correct bit in both the IENF and IENR registers to enable both edges - will this work?
Thanks.
Thanks.
06-15-2016
09:55 AM
1,007件の閲覧回数
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Content originally posted in LPCWare by mozmck on Wed Aug 28 18:36:22 MST 2013
Thanks, I thought that might work but was not sure. I'll have boards to test with in a few days but thought I'd ask first and maybe save some time.
06-15-2016
09:55 AM
1,007件の閲覧回数
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Content originally posted in LPCWare by tha on Wed Aug 28 16:51:01 MST 2013
Hi Mozmck,
Yes, the pin interrupt will work with rising and falling edge. You can use this little code snippet to test it out yourself:
You can monitor which edge is detected by setting a break point inside the PIN_INT0_IRQHandler() function.
The gpio.c file and gpio.h is from the code bundle.
Hi Mozmck,
#include "LPC13Uxx.h"/* LPC13Uxx Peripheral Registers */ #include "gpio.h" int main (void) { GPIOInit(); /* use port0_1 as input event, interrupt test. */ GPIOSetDir( PORT0, 1, 0 ); /* channel 0, port0, bit 1, edge trigger, rising edge. */ //Set P0_1 detect rising edge GPIOSetPinInterrupt( 0, 0, 1, 0, 1 ); //Now set it for falling edge also LPC_GPIO_PIN_INT->IENF |= (0x1<<0);/* faling edge */ GPIOPinIntEnable( 0, 1 ); while(1); } |
