IABR0 register in a LPC84x
1,276 次查看
Murtn
I'm currently writing a program for the LPC845 ( on lpc845-brk).
When reading the user manual (UM11029, Rev. 1.6 - 8 December 2017) I noticed in chapter 7.4 NVIC register description that the IABR0 register is described. However a Cortex-M0+, on which the LPC845 is based, does not contain this register.
Is this register available/functional in a LPC845?
Kind regards,
标记 (3)
1,182 次查看
diego_charles
Hi Maarten,
Thank you for report!
Since  IABR register is not defined in the NVIC_Type  structure (for the M0+ in the ARM CMSIS headers) it it’s not intended to be functional.
I will let the LPC applications team know about this delta with the user manual.
Kind regards,
Diego.
1,183 次查看
diego_charles
Hi Maarten,
Kind regards,
Diego.
