Debugging in MCUXpresso IDE
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
I'm currently working UART communication of receiving while debugging in the controller with the board, it occurs Hardfault error so that I couldn't debug. Though when working in EVK board debugging works without any issue. And I have attached the screenshot below.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Could you please tell us which MCU/part are you using please?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
MCUXpresso IDE V 11.8.0_1165 & LPC55S16 microcontroller
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello @DHARSAN
Do you mean the same example works well on EVK board, while there is issue with your own board?
How about debug a simple led or hello world demo on your custom board? Or create a new project based on your chip to test. Pay attention choose correct part number.
Alice
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
receiving same data in controller when transmitting different data from uart module
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello @DHARSAN
"receiving same data in controller when transmitting different data from uart module"
->> If so, you need check your code.
Alice
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
But I'm working in the SDK example code which is modified for receiving only
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello @DHARSAN
1> So recommend you first use SDK demo without any modification.
2> Check whether enable UART clock and pin clock you used.
Alice
