Debugging in MCUXpresso IDE
456 次查看
DHARSAN
   I'm currently working UART communication of receiving while debugging in the controller with the board, it occurs Hardfault error so that I couldn't debug. Though when working in EVK board debugging works without any issue. And I have attached the screenshot below.
7 回复数
442 次查看
_Leo_
Could you please tell us which MCU/part are you using please?
416 次查看
DHARSAN
MCUXpresso IDE V 11.8.0_1165 & LPC55S16 microcontroller
405 次查看
Hello @DHARSAN
Do you mean the same example works well on EVK board, while there is issue with your own board?
How about debug a simple led or hello world demo on your custom board? Or create a new project based on your chip to test. Pay attention choose correct part number.
Alice
398 次查看
DHARSAN
receiving same data in controller when transmitting different data from uart module
388 次查看
Hello @DHARSAN
"receiving same data in controller when transmitting different data from uart module"
->> If so, you need check your code.
Alice
379 次查看
DHARSAN
But I'm working in the SDK example code  which is modified for receiving only
254 次查看
Hello @DHARSAN
1> So recommend you first use SDK demo without any modification.
2> Check whether enable UART clock and pin clock you used.
Alice
