Can anyone provide driver file link to CAN2.0(J1939)/Timer/GPIO .I am using LPC11C24 customized board
641 次查看
sridharan
Can anyone provide driver file link to  CAN2.0/Timer/GPIO .I am using LPC11C24 customized board
457 次查看
kerryzhou
Hi Sridharan TechM,
    About the LPC11C24 drivers, please refer to these links:
1. Sample code bundle
    MDK and IAR project:
Sample Code Bundle for LPC11xx Peripherals using Keil's MDK-ARM | www.LPCware.com
   LPCXpresso IDE project
Sample Code Bundle for LPC11xx Peripherals using NXP LPCXpresso | www.LPCware.com
2. LPCopen code
 MDK and IAR project
http://www.nxp.com/assets/downloads/data/en/software/lpcopen_v2_00a_keil_iar_nxp_lpcxpresso_11c24.zi...
http://www.nxp.com/assets/downloads/data/en/software/lpcopen_v2_00a_lpcxpresso_nxp_lpcxpresso_11c24....
All these sample codes contains the CAN, timer, GPIO drivers.
But the about the CAN driver, it is just the chip bottom driver. J1939 is a higher layer protocol based on the software. I have search the website, we don't have this protocal code for LPC11C24, so you need to find a J1939 stack and add it to the LPC11C24 project by yourself.
Wish it helps you!
Kerry
