currently i am doing voice recording project using LPC1768 with mic(ADC). i am going store the ADC sampling data 8KHz in flash memory (in datasheet shows the 200khz). please anyone send ADC configuration of LPC1768 with 8KHz sampling rate and my CCLK is 100MHZ.
Thank you..............
Hi frnds,
i am trying to program led blinking in P0_30 using LPC1225/301 microcontroller. there is no error in this program. but led is not blinking. can anyone suggest me what is wrong in this program.
#include<lpc122x.h>
void delay(unsigned short int ms) ;
int main(void)
LPC_SYSCON->SYSAHBCLKCTRL |=(1UL<<31)|(1<<30)|(1<<29)|(1<<16);
LPC_IOCON->PIO0_30 &=~0xFF;
LPC_IOCON->PIO0_30 |= (1<<4)|(1<<7);
LPC_GPIO0->DIR |= (1<<30);
LPC_GPIO0->CLR |= (1<<30);
while(1)
LPC_GPIO0->SET |= (1<<30);
delay(1000);
delay(1000);
unsigned short int j;
unsigned long i;
for(j=0;j<ms;j++)
for(i=0;i<1700;i++);
Hi Dhinesh E,
Thanks for your reply.
I'd highly recommend you to refer to BLINKY demo from the ARM Keil for details.
MCB1200 User's Guide: Example Programs
TIC
Hi Dhinesh E,
TIC
I got a small doubt. In LPC1768/69 ADC is SAR type. for 12 bit resolution it should take 12 cycles for compete conversion. But in user manual mentioned that,
A non-burst mode conversion requires
65 clocks and a burst mode conversion requires 64 clocks.
Can you explain this?
Muralidhar.
Hi jeremyzhou,
Good Morning!
Thank you so much for response my queries.
As i mentioned i need sample rate 8000Hz. Based on your calculation i divide CLKDIV 193 ~ 195
i got frequency
7971 HZ for CLKDIV 193 how I calculated: 100MHz / 193 = 518134
7730 HZ for CLKDIV 194 then, 518134 / 65 = 7971 Hz
7889 HZ for CLKDIV 195
Based on my calculation i got those value in that 7971HZ is nearest of my sample rate 8000Hz .
IS IT OK FOR MY ADC requirement? or still i need to optimize the to get the 8000Hz
Thank you,
Dhinesh E
Hi Dhinesh E,
I think it is Okay.
TIC
Hi jeremyzhou,
Good Morning............!
Thank you for your reply,
I am using the MIC as a input for ADC. As you suggested i configured the ADC sample rate 8000Hz.
Now i am going to store the voice signal for 5 sec in flash memory.(same like voice recoder IC).
After whenever i need i will playback again the 5 sec of stored voice through DAC(speaker).
can you tell me how to store the voice signal into the flash memory at least 5 sec?????
Important note:
Using LPC1768,
CCPU rate: 100MHz
ADC sample rate: 8000HZ
12 bit ADC
flash memory 512 K bytes
Thank you
Have a beautiful day.
Do you have any sample code please share me.............
Hi Dhinesh E,
I don't think the way of storing the ADC value in the flash is good choice, and I'd highly recommend that you can store the ADC values by using the DMA mechanism, otherwise the DMA mechanism is also suit for the transferring the ADC values to the DAC.
These application will give you some inspirations.
www.nxp.com/docs/en/application-note/AN10917.zip
www.nxp.com/docs/en/application-note/AN11178.zip
TIC
Dear jeremyzhou,
Thanks you so much for your reply.
yes what you said correct, otherwise i will use external flash memory using SPI protocol. i will store the ADC value(using MIC) in external SPI flash memory.
Do you have any code or any study material for storing the ADC(using MIC) value in any External SPI flash memory.
Dhinesh E
Embedded Engineer - R&D
