spi driver crash in KSDK_1.3.0
次の代わりに検索
1,023件の閲覧回数
keetle
I am testing K64 spi module in KSDK_1.3.0 and KDS3.0.
I do like this:
uint32_t Spi_Init(void)
     .......        // init mux pin, variable  etc.
     _int_install_isr(SPI0_IRQn, (INT_ISR_FPTR)SPI0_IRQHandler, NULL);
     DSPI_DRV_MasterInit(0, &spiBus_Status, &masterUserConfig);                                                     //return OK
     DSPI_DRV_MasterConfigureBus(0, &masterDevice, &calculatedBaudRate);                                   //return OK
     DSPI_DRV_MasterTransferBlocking(0, &masterDevice, sendBuffer, receiveBuffer, 6, 5000U);        // when the app start, it crash at here
I debug it and the app do like this:
when the appliaction start, it crash at "DSPI_DRV_MasterTransferBlocking".
the mqx issue "mqx_unhandled_interrupt" .
it crash when "OSA_SemaPost(&dspiState->irqSync)"  execute in function  "static void DSPI_DRV_MasterCompleteTransfer(uint32_t instance)";
what is wrong?
572件の閲覧回数
adriancano
This is caused because you are naming your interrupt handler with the same name as the CMSIS startup code file. This does not allow MQX to install its own handler and the MQX ISR is not called when the interrupt occurs.
You can check more information regarding Interrupt handling in KSDK in the next document from colleague Jorge Gonzalez: Interrupt handling with KSDK and Kinetis Design Studio
Attached you can find an example using SPI drivers within KSDK + MQX. Please check the install interrupt function and the handler name.
I hope this information can help you.
Adrian
6 返答(返信)
571件の閲覧回数
keetle
Can someone help me?:smileyhappy:
573件の閲覧回数
adriancano
Adrian
571件の閲覧回数
keetle
I checked your answer today, the application run smoothly.
Thank you! :smileyhappy:
572件の閲覧回数
Hi keetle,
- Please step  into the function of DSPI_DRV_MasterTransferBlocking(), check it will crash when run which specific code .
- And under the KSDK1.3 , there is a SPI demo about k64 , here :
  Freescale\KSDK_1.3.0\examples\frdmk64f\driver_examples\dspi
- Under the KSDK,  there also is a MQX-spi demo , please refer to :
Freescale\KSDK_1.3.0\rtos\mqx\mqx\examples\dspi
Hope it helps
A.kce
572件の閲覧回数
keetle
and I finally find it go into HardFault_IRQn.
Infact I almost use KSDK1.3.0 code like I show before, all API is from offical.
the SDK I used is base on  TWR-64F120M platform and MQX,  my device is MK64FX512VLL12, is there any problem?
572件の閲覧回数
keetle
I follow the debug process;
when I run function  DSPI_DRV_MasterTransferBlocking(), it will invoke the IRQHandler. After SPI module finish transmittion, it invoke function OSA_SemaPost(&dspiState->irqSync) to inform main task wake up.
However , when the SPI IRQ executing OSA_SemaPost(), it crash at:
_mqx_uint _lwsem_post(  LWSEM_STRUCT_PTR sem_ptr)
    _INT_DISABLE();
    if ((sem_ptr->VALUE >= 0) && (_QUEUE_GET_SIZE(&sem_ptr->TD_QUEUE)))
        _QUEUE_DEQUEUE(&sem_ptr->TD_QUEUE, td_ptr);
        _BACKUP_POINTER(td_ptr, TD_STRUCT, AUX_QUEUE);
        _TIME_DEQUEUE(td_ptr, kernel_data);
        td_ptr->INFO = 0; /* Signal that post is activating the task */
        _TASK_READY(td_ptr, kernel_data);
        _CHECK_RUN_SCHEDULER();                                    /* Let higher priority task run */     //my app crash here
    else
        ++sem_ptr->VALUE;
    } /* Endif */
    _INT_ENABLE();
