I'm using lwIP tcpecho demo example given with KDSK1.3.0.
It successfully connected to TCP client as server, but my application needs TCP client on K64 MCU.
How can i make TCP client on K64 using KSDK.
Punit Kumar
Hi Punit,
please can you try it according this example?
LWIP stack is CPU independent.
I hope this helps.
In case of any issue, please let me know.
Kind Regards,
Iva
Hi ivadorazinova
thanks for the response.
I've implimented TCP client using raw api of lwIP.
But i cannot detect a connection drop (removed cable) after once connected successfully.
can you help me over that?
thanks in advance
Punit Kumar
Thanks for your response,
I've made it worked, but now have another problem regarding the same.
you can find it with title "problem while TCP Transmission of continuous data"
Reply if you can help me over that.
I've used RAW APIs.
Thanks Again
Punit Kumar
