[MQX on K64] post a semaphore during an interrupt creates a hardfault
Search instead for
samuelboivineau
I have tried to use most of the project sai_demo to test the SAI peripheral, but I have been stuck for a few days by a semaphore posted during an interrupt that creates a hardfault. The target is a K64F120M.
In fsl_soundcard.c, the function OSA_SemaPost(&buffer->sem) is used by SND_TxCallback, called by SND_TxDmaCallback, that is called by a DMA interrupt if my understanding is correct :
- EDMA_DRV_InstallCallback(&ctrl->dma_channel, SND_TxDmaCallback, (void *)card);
In the MQX documentation, I don't see anything about interrupt context.
And if I follow the post of the semaphore, then the sw goes to _lwsem_post, and sees that the semaphore is at 0, and a task is waiting for it, so the task is set ready and _CHECK_RUN_SCHEDULER is called. Then I jump into my HardFault_Handler, and I got those registers :
r0 = 0x1
r1 = 0x2000049c
r2 = 0x1
r3 = 0x1
r12 = 0x1fff0be0
lr = 0x30ab3          => in the code of _lwsem_wait_ticks, after _sched_execute_scheduler_internal and the result.
pc = 0x4b6               => instruction "bx lr"  in _sched_execute_scheduler_internal (defined by macro as _CHECK_RUN_SCHEDULER)
psr = 0x1000000
So is it ok to post a semaphore inside an interrupt ?
Maybe I have a missed some configuration ?
Currently I am doing some polling but it's not the aim for a rtos ...
What is also curious is the link register with a value with 3 at the end, there is no alignement required ? It would be some register over-written by someone ? but who ? And which stack or heap would be impacted ?
Thanks for your help
keetle
It means that your interrup function name should not be same as the CMSIS startup code file interrupt function name.
so your function name "DMA0_IRQHandler" etc are illegal.
you can modify the illegal function name like this:
void MQX_DMA0_IRQHandler(void)
    EDMA_DRV_IRQHandler(0);
after that, register interrupt function
_int_install_isr(DMA0_IRQn, (INT_ISR_FPTR)MQX_DMA0_IRQHandler, NULL);
after all,  it should be OK.:smileyhappy:
keetle
I think you have met the same doubt I have before
I hope this link page will help you.
https://community.freescale.com/thread/379827
samuelboivineau
Thanks for your answer, I've looked at the link, but I am using the irq functions of the example, so it doesn't seem to be an issue. And I don't see how can I change it. They are defined this way :
// DMA (0 to 15)
void DMA0_IRQHandler(void)
// SAI
void I2S0_Tx_IRQHandler(void)
    SAI_DRV_TxIRQHandler(0U);
void I2S0_Rx_IRQHandler(void)
    SAI_DRV_RxIRQHandler(0U);
If anyone has an idea, let me know !
keetle
samuelboivineau
Your solution solved the issue. Thanks a lot !
