[MQX on K64] post a semaphore during an interrupt creates a hardfault
935 次查看
samuelboivineau
I have tried to use most of the project sai_demo to test the SAI peripheral, but I have been stuck for a few days by a semaphore posted during an interrupt that creates a hardfault. The target is a K64F120M.
In fsl_soundcard.c, the function OSA_SemaPost(&buffer->sem) is used by SND_TxCallback, called by SND_TxDmaCallback, that is called by a DMA interrupt if my understanding is correct :
- EDMA_DRV_InstallCallback(&ctrl->dma_channel, SND_TxDmaCallback, (void *)card);
In the MQX documentation, I don't see anything about interrupt context.
And if I follow the post of the semaphore, then the sw goes to _lwsem_post, and sees that the semaphore is at 0, and a task is waiting for it, so the task is set ready and _CHECK_RUN_SCHEDULER is called. Then I jump into my HardFault_Handler, and I got those registers :
r0 = 0x1
r1 = 0x2000049c
r2 = 0x1
r3 = 0x1
r12 = 0x1fff0be0
lr = 0x30ab3          => in the code of _lwsem_wait_ticks, after _sched_execute_scheduler_internal and the result.
pc = 0x4b6               => instruction "bx lr"  in _sched_execute_scheduler_internal (defined by macro as _CHECK_RUN_SCHEDULER)
psr = 0x1000000
So is it ok to post a semaphore inside an interrupt ?
Maybe I have a missed some configuration ?
Currently I am doing some polling but it's not the aim for a rtos ...
What is also curious is the link register with a value with 3 at the end, there is no alignement required ? It would be some register over-written by someone ? but who ? And which stack or heap would be impacted ?
Thanks for your help
550 次查看
keetle
It means that your interrup function name should not be same as the CMSIS startup code file interrupt function name.
so your function name "DMA0_IRQHandler" etc are illegal.
you can modify the illegal function name like this:
void MQX_DMA0_IRQHandler(void)
    EDMA_DRV_IRQHandler(0);
after that, register interrupt function
_int_install_isr(DMA0_IRQn, (INT_ISR_FPTR)MQX_DMA0_IRQHandler, NULL);
after all,  it should be OK.:smileyhappy:
4 回复数
550 次查看
keetle
I think you have met the same doubt I have before
I hope this link page will help you.
https://community.freescale.com/thread/379827
550 次查看
samuelboivineau
Thanks for your answer, I've looked at the link, but I am using the irq functions of the example, so it doesn't seem to be an issue. And I don't see how can I change it. They are defined this way :
// DMA (0 to 15)
void DMA0_IRQHandler(void)
// SAI
void I2S0_Tx_IRQHandler(void)
    SAI_DRV_TxIRQHandler(0U);
void I2S0_Rx_IRQHandler(void)
    SAI_DRV_RxIRQHandler(0U);
If anyone has an idea, let me know !
551 次查看
keetle
548 次查看
samuelboivineau
Your solution solved the issue. Thanks a lot !
