I´m currently porting an application from a MCU that is using the lwip stack (1.4.0) to a Kinetis K64F120.
As far as I can understand, there is a variant of the lwip-Stack included in the Kinetis SDK.
Some parts are missing from what I can see, for example the unit tests provided by the lwip stack.
My application is using some of the applications provided in the contrib-1.4.0 package which is missing as well.
Does anyone know which version the lwIP stack provided by the Kinetis SDK is based upon?
Anders
Solved! Go to Solution.
the version provided by KSDK is 1.4.1.
please refer to SW-Content-Register-KSDK-1.0.0.txt which is located in KSDK installation folder.
lwIP TCP/IP Stack | Description: A light-weight TCP/IP stack |
Version: 1.4.1 | |
Author: Swedish Institute of Computer Science | |
License: Open Source - BSD-3-Clause | |
Format: source code | |
URL: http://savannah.nongnu.org/projects/lwip/ | |
Version: 1.4.1 | |
