FLEXIO_I2C_MasterTransferBlocking implementation is missing from SDK 2.0
882 次查看
alexfeinman
If I generate an SDK for an SKU that has FLEXIO (1.0 or 1.1), the resulting fsl_flexio_i2c_master.h contains the following definition:
status_t FLEXIO_I2C_MasterTransferBlocking(FLEXIO_I2C_Type *base,
                                           flexio_i2c_master_handle_t *handle,
                                           flexio_i2c_master_transfer_t *xfer);
However the corresponding fsl_flexio_i2c_master.c does not have the implementation. Obviously, I can implement it myself using FLEXIO_I2C_MasterTransferNonBlocking and a loop, but it looks like an unintentional omission that needs to be corrected
标记 (2)
674 次查看
DavidS
Hi Alex,
Good find.
I will notify the KSDK_v2 team.
UPDATE:
status_t FLEXIO_I2C_MasterTransferBlocking(FLEXIO_I2C_Type *base, flexio_i2c_master_transfer_t *xfer)
    assert(xfer);
    flexio_i2c_master_handle_t tmpHandle;
    uint32_t statusFlags;
    uint32_t result = kStatus_Success;
    FLEXIO_I2C_MasterTransferCreateHandle(base, &tmpHandle, NULL, NULL);
    /* Set up transfer machine. */
    FLEXIO_I2C_MasterTransferInitStateMachine(base, &tmpHandle, xfer);
    do
        /* Wait either tx empty or rx full flag is asserted. */
        while (!((statusFlags = FLEXIO_I2C_MasterGetStatusFlags(base)) &
                 (kFLEXIO_I2C_TxEmptyFlag | kFLEXIO_I2C_RxFullFlag)))
        result = FLEXIO_I2C_MasterTransferRunStateMachine(base, &tmpHandle, statusFlags);
    } while ((tmpHandle.state != kFLEXIO_I2C_Idle) && (result == kStatus_Success));
    return result;
The KSDK_v2 team is looking into the issue.
David
http://www.nxp.com/products/identification-and-security/nfc-and-reader-ics/connected-tag-solutions/n...
674 次查看
alexfeinman
David,
This appears to be taken from the K80 SDK. It seems that unlike FLEXIO 1.1, the SDKs for FLEXIO 1.0 parts, such as KL17 I am using, are based on older code and do not have some of the calls referenced here implemented (e.g. FLEXIO_I2C_MasterTransferInitStateMachine)
UPDATE: Sorry, was looking it the wrong place. This works fine. Thank you. Hoping to see this in the SDK eventually.
