DSPI Master Transfer in KSDK 2.0?
次の代わりに検索
520件の閲覧回数
mooreken
Hello, I was wondering if anyone else had run into this kind of issue working the DSPI_MasterTransferBlocking function in the latest version of the KSDK. I am working on with a SPI EEPROM chip and a MK22FN512VLL12, essentially I have a function that accepts a pointer to a struct, the size of that struct in bytes, and the starting location in EEPROM to write to.
uint8_t read_eeprom( void *setup, uint16_t size, uint16_t addr)
The DSPI_MasterTransferBlocking function needs the SPI_Type pointer and a pointer to the dspi_transfer_t struct. This struct is created in the following fashion.
dspi_transfer_t eeprom_command;
eeprom_command.txData = (uint8_t *) calloc(200, sizeof(uint8_t));
eeprom_command.rxData = (uint8_t *) calloc(200, sizeof(uint8_t));
Next, I populate the eeprom transfer data (txData) with the contents of the read command and the address.
eeprom_command.txData[0] = 0x03; //read command
eeprom_command.txData[1] = (uint8_t) (addr >> 8);
eeprom_command.txData[2] = (uint8_t) (addr & 0x00FF);
Now here's where I have my first question, the dataSize field in the dspi_transfer_t struct. I assume this pertains to both the transfer data and the received data. Or does this field only for the txData length?
eeprom_command.dataSize = size + 3? or just 3?
Next is the configFlags field, set this to (kDSPI_MasterCtar1 | kDSPI_MasterPcs1) based off hardware. Then I enable the EEPROM chip select and send the command.
DSPI_MasterTransferBlocking(SPI1, &eeprom_command);
However, I read 0xFF in all the rxData locations... I have a KSDK 1.3 version of this code as well, so I used that to write data and used 2.0 to read that data back.
Any help is appreciated!
タグ(3)
278件の閲覧回数
mooreken
Found it, looks like my config flags were off.
279件の閲覧回数
mooreken
