I am beginner of Codewarrior.
I want to try USB_CDC with MK20 in ProcessorExpert.
But,in FSL_USB_CDC Component,how to add MK20 in cpu popupmenu?(i used usb_stack_4.1.1.)
Thank u
Hi Sreerama,
Which K20 MCU are you using? Maybe the following post created by our colleague Erich Styger is helpful for you, it explains the usage of the FRDM-K20D50M as USB CDC with Processor Expert:
https://mcuoneclipse.com/2013/04/27/usb-cdc-with-the-frdm-k20d50m/
Hope it helps!
Carlos Mendoza
Technical Support Engineer
