mingw32-make: *** [HORNO2.elf] Error1 help me!
2,157 次查看
alejandro_df
I have an application where I am using kl25. with usb stack with  processor expert does not send a single error in the code but when copilar just sends me the following error:
Description Resource Path Location Type
mingw32-make: *** [HORNO2.elf] Error 1 HORNO2 C / C + + Problem
Message was edited by: Monica Arvizu
973 次查看
apanecatl
Senior Contributor II
I suggest you include your project code to review it, the mingw32-make error is quite common and not very specific, also include the part you are using, i.e.: MK60DN512
973 次查看
alejandro_df
Sorry. the warnings are from another project. my project does not send a single warning
973 次查看
Monica
Senior Contributor III
Hola Alejandro!
I removed the warning section from your post to avoid confusion...let me know if any concern.
Monica.
