freedom board as programmer
次の代わりに検索
325件の閲覧回数
andyvoss
I have a Freedom KE02 board I am using as a programmer for a stand-alone KE02 system.  I am using J7 as the programming interface, after disconnecting the dataline from the on-board KE02.
I have to use the stand-alone system at 5V.  In order to keep using the Freedom board while powered up at 5V, I will disconnect V3.3 from J7.  Should I put a 1KOhm resistor in line with the SWD_DIO or CLK lines?  I am using TXD and RXD with 1KOhm resistors in line with those signals.
Please help, I also use FreeMaster so having the stand-alone and the Freedom boards connected while operating is required.  I just don't want to hurt anything.
Thank you!
Andy.
145件の閲覧回数
jeremyzhou
Hi Andy,
Regarding to your query, I'd highly recommend you to use the 3.3-5 logic convert chip. I think it's good way to work it out.
You can learn the more information about it by through the link as below.
http://www.nxp.com/documents/application_note/AN240.pdf
Ping
